Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Common sense and a sense of humor are the same thing, moving at
different speeds. A sense of humor is just common sense, dancing.
-- Clive James
-- Clive James
www.control.com/rss/
i want to know if Triconex TMR PLC has inherent line monitoring facility.
Triconex has two active platforms. The Tricon (Chassis) and the Trident (baseplates). The Tricon has been offering Supervised DO modules for many many years. There are 3 different SDO flavors available in different voltage levels. There is a current monitor (cannot be used for non-incendive circuits), a voltage monitor, and a point selectable supervised module. The Digital Inputs are line monitored by using an AI module and a resistor network. This is a requirement for Fire and Gas, which Triconex has hundreds of installations. The Trident will have an SDO in 2009, but for now there is an MTL solution available which uses a standard DO.
Related articles from Control
Engineering magazine- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
- Relays: Slim industrial relays have push-in terminal sockets
Subject to its Terms of Use.
