member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Nothing is faster than the speed of light ...
To prove this to yourself, try opening the refrigerator door before the
light comes on.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Instrumentation department...
Load Cell signal Cable
Posted by Arun Meyyappan on 12 July, 2008 - 5:11 pm
Can i use a 1.0Sq. mm signal cable to transmit a load cell output signal from the field to control room at an opproximate distance of 200 mtrs" what are the possible defects that can occurs on the receiving end.
Can i get specfication for the Load cell cable?
Posted by Roy Matson on 13 July, 2008 - 12:17 pm
For a typical cell your cable should be shielded with 6 wires (3 pair)
Pair 1 from the control room to power the cell (excitation)
Pair 2 to bring back the cell output
Pair 3 to read back the cell excitation voltage. Pair 3 is normally connected to the same cell terminals as pair 1 and reads the actual voltage applied across the cell. As you know the cell output is rated in mV/V so it's important to ignore the voltage drop in pair 1
I have often used twisted pair instrument cable for this purpose however a 6 conductor shielded will also work.
If your cell is not used for a weigh scale and accuracy is not required you may get away with just 4 conductor shielded.
Post your systems Make & Model, you might get a clearer answer. Most system manuals show how to extend the cell cables
Good luck
Roy
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
