member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
No matter how subtle the wizard, a knife in the shoulder blades will
seriously cramp his style.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the operations department...
Substation DC problem
Engineering and workplace issues. topic
Posted by Solo on 23 July, 2008 - 11:01 pm
The negative pole of the 60VDC battery bank keeps going greenish. l mean the terminal changes from its silverish color to greenish after a period and the connecting cable to the rectifier also becomes wet. This happens to only the main negative terminal. I guess some chemistry is going on. Any solutions?
Posted by Curt Wuollet on 23 July, 2008 - 11:54 pm
You have some electrolyte leakage around the pole and it's reacting with the metal. The seal is often broken when someone gets too enthusiastic with a wrench tightening terminals. Test with litmus. not knowing what chemistry your battery uses makes it hard to predict the reaction, but this is extremely common with lead acid batteries because the terminations are soft lead and stressing them loosens them because lead doesn't spring back from deflection.
cww
Posted by Roy Matson on 24 July, 2008 - 11:50 pm
Petroleum jelly is your best friend around lead acid batteries, smear that over all the terminals and you won't have to worry again.
Roy
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
