member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Office Automation, n.:
The use of computers to improve efficiency by removing anyone
you would want to talk with over coffee.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Automation Problem department...
S5 PLC QVZ error and outputs blinking
Posted by AK Khairkar on 30 July, 2008 - 1:39 am
I have a S5 135U from Siemens which gives QVZ (i/o) error on the CPU 928B intermittently, and the outputs starts blinking w/o actually the logic operating. This has caused serious damage to hydraulic motor contactors. When you see ladder the logic output is steady but it blinks on cards, and CPU, QVZ also blinks. CPU used is CPU928B.
When the program is washed and reloaded it works for few days without problem.
AK Khairkar
Posted by ALI on 26 August, 2008 - 9:54 am
i think if you change (Q) in program or change output card your problems will be solved.
Posted by ST - WP on 14 September, 2008 - 6:34 pm
I had once incident when I must change on new a CPU 928B. The CPU 928B (with eprom) has a problem with running - go to run mode OK. Previous a Service Man made check a base plane (connection between card and a base plane, solder point ). Sometime the CPU working Ok, but few mounts leter a problem was again. Only helped change the CPU. Maybe You change your a CPU on another a proficient CPU?
Slav
Posted by Amit Gupta on 15 September, 2008 - 11:45 pm
Dear Mr. Khairkar,
You may send you detailed info of problems in S5 if not resolved till date to our email: sitek at vsnl.net
We assure you of our best possible support for SIMATIC S5 installations still working in your plant.
Amit Gupta
SITEK Automation & Solutions
2, Bhumiraj Manor, Plot #3, Sec-14,
Off. Palm Beach Road, Sanpada(E)
Navi Mumbai (India) - 400705
Tel / Fax : +91 22 27811980
Email : sitek@vsnl.net
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
