Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
'I believe in getting into hot water; it keeps you clean."
-- G. K. Chesterton
-- G. K. Chesterton
www.control.com/rss/
Requesting info on intrinsically safe wireless display for use inside a building, size of approx 100' by 200', I am looking for a portable display that via wireless link to a ControlLogix processor will continuously provide a readout of one process variable. Oh yes, the display unit will have to be rated for class 1 div 1 service. Any suggestions? I have a spare Modbus port available (from a Prosoft module) if that helps.
Hugo
Hugo
In the event, your wireless unit need to link through ethernet to devices, you can consider MTL IS Ethernet solutions.
http://www.mtl-inst.com/newsroom/press_releases/pr47 4.htm
Furthermore, MTL through Elpro Tech. do has solution for wireless connection with AB PLC through EthernetIP, DF1, DeviceNet gateways.
Related articles from Control
Engineering magazine- Signal conditioners support universal input, feature detachable display
- Motion control: Omron selects EtherCAT as its next motion bus system
- Wireless: Adoption trends in factory automation
- Tutorial: Instrumentation / DCS integration languages, part 2: FDT
- Connectivity: Embedded LAN module with minimum programming
- New 1-1/8 in. M23 connectors provide 19 pins
- Hatching distributed automation architectures
- Quatech expands Airborne wireless line
- Ethernet drives industrial network growth
- Wireless networks: ISA creates wireless factory automation standard working group
Subject to its Terms of Use.
