member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Q: How many IBM cpu's does it take to do a logical right shift?
A: 33. 1 to hold the bits and 32 to push the register.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Swimming in Mud department...
Mud Level inside a Thickener
Application Questions and Problems topic
Posted by Thys on 9 August, 2008 - 1:29 pm
I'm looking for an Instrument of some sort that can show me the Mud Level inside a Thickener. I 'm using a Turbidity Transmitter to give me the clarity of the water but I need more. I'm in the Gold Mining Industry
Posted by Roy Matson on 10 August, 2008 - 3:42 pm
I worked in mining for a lot of years, most of the thickeners had a float device. A SS ball about 6" diameter sliding on a length of SS tube. A magnet inside the float activated a series of reed switches inside the tube. I think it was in about 5% steps.
The ball is filled with sand or water until it just sinks in water (floats on mud).
If you put a flange mounted transmitter on the bottom cone zeroed on water it will tell you the percentage of mud to water but not the actual level This can be quite useful.
I have also been told (haven't tried it) that a regular ultrasonic transmitter dipped in the water will work. The speed of sound is much higher in water than air.
Hope this helps
Roy
Posted by wboyes on 10 August, 2008 - 8:26 pm
I've used the ultrasonic thingys, from several different manufacturers, and they seem to work okay until there's an upset, or the rag layer rises. The big problem with the ultrasonics (and I think somebody makes one that is optical, or infrared) is that they have to be picked up when the traveling bridge of the clarifier goes around. This is a mechanical device kludge, and
is prone to failure.
I've also used a Sludge Judge(tm) which is a long clear plastic pipe with a cap and a release on one end. This is "calibrated" by having rule lines painted on it. You can buy them or you can make them.
Walt Boyes
Editor in Chief
Control and Controlglobal.com
www.controlglobal.com
Mailto:wboyes@putman.net
Read my blog SoundOFF!! At www.controlglobal.com/soundoff
Posted by Roy Matson on 12 August, 2008 - 2:30 am
Walt,
I share your lack of faith in ultrasonics especially if the interface layer is not well defined.
I searched the web without success trying to find the float type I described, they were very reliable but would not of course measure below the upper rake level. I came across a device from Endress&Hauser that winches down a displacer between rake passings. This is an idea I have seen built on site from time to time.
I am not convinced that bed level is that important provided the overflow is clear. I have had some success in getting operators to use the DP cell as a measure of total mud along with underflow density and flocculent ratioed to feed rate.
Roy
Posted by Kaz on 21 August, 2008 - 12:56 am
Mate,
Would you know who makes the SS ball devices to accurately measure mud levels?
Rgds,
Kaz
Posted by Roy Matson on 22 August, 2008 - 2:13 am
Kaz,
Yay, I finally found it!
http://apitechs.net/pitProbe.aspx#gemProbeSensor
This shows a picture of one for oilfield application.
http://www.gemssensors.com/Content.aspx?id=2842
Shows you the 8" SS ball float.
I'm not sure if Gems know that it's used for interface. I suspect the thickener manufacturers just modified the ball by adding a 1/8" NPT plug. Just add water until it sinks.
Good Luck,
Roy
Posted by Roy Matson on 23 August, 2008 - 7:22 pm
Kaz,
Drop me an e-mail and I will send some thoughts on thickener roy_matson @ yahoo.ca
Roy
Posted by Anonymous on 15 September, 2008 - 11:44 pm
You could try the SmartDiver.
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
