Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Air is water with holes in it
www.control.com/rss/
Can I convert output signal 0-10V from a sensor directly by means of resistors to 0-1v, instead of using signal conditioning devices?
Short answer - Yes.
Just use 2 resistors in series to give the correct voltage.
You might want to add a trimpot for fine adjustment.
Roy
Roy
It's been too many years since electronics class, but, if I recall correctly depending on the current output capability of the 0-10 VDC source, and the availability of resistors (they don't always come in convenient values!) you could use something like a 900 ohm resistor in series with a 100 ohm resistor (for a total circuit current draw of (10V/1000 ohms = 0.010 mA).
As Roy Matson suggested, you could use a trimpot for "correcting" the signal. Or, just use two pots in series, set one for 900 ohms and the other for 100 ohms. No need to worry about resistor values and tolerances.
Related articles from Control
Engineering magazine- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
- Relays: Slim industrial relays have push-in terminal sockets
Subject to its Terms of Use.
