member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Best of all is never to have been born. Second best is to die soon.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
PC industrial control
Computers in manufacturing; also hardware discussion. topic
Posted by Eduard on 19 August, 2008 - 12:40 am
I would like to know if there is any software out there that would allow me to use Ubuntu or any Linux distro to interface with I/O modules. By interfacing I mean to say I would like to be able to control say the starting of a motor, or the open/close state of valves. The programming I can do in any language supported by Linux distros, all I would like to know is if there is a program out there with an open source that I could modify at my leisure.
On a similar note, I am open to restrictions, such as, I am willing to receive input about examples of how others have interfaced with I/O modules via PC. It's best to follow others' examples as I'd be swimming charted waters right there.
Thank you in advance.
Posted by James Ingraham on 20 August, 2008 - 1:01 am
Yes. Lots. The most obvious is to connect to an I/O module over Ethernet.
Modbus/TCP is easiest. http://www.modbus.org Lots of I/O options including Wago, Aromat, Turck, etc.
EtherCAT is pretty cool. http://ethercatmaster.berlios.de There are fewer options for I/O, Beckhoff being your main choice.
I don't like Ethernet PowerLink (EPL) because it requires the use of hubs instead of switches, but at least they have an open source implementation. http://sourceforge.net/projects/openpowerlink B&R is the main I/O supplier, but Wago is also available.
There are other Ethernet modules, like Advantech's ADAM series, Elexol's Ether IO 24 R, Opto-22's SNAP I/O, etc.
You can use USB instead, with Advantech again, or National Instruments. You can even do Firewire with Wago.
There are PCI and even PCI Express plug-in cards. Advantech, National Instruments, Opto-22, and a host of others.
Virtually all of this stuff has Linux drivers, or documentation on how to implement in Linux. Essentially any language will work.
-James Ingraham
Sage Automation, Inc.
Posted by Michael Griffin on 20 August, 2008 - 1:26 am
I have a project at: http://sourceforge.net/projects/mblogic/
Go to http://sourceforge.net/project/showfiles.php?group_id=228414 to find the latest release. Have a look at the project web pages for documentation.
http://mblogic.sourceforge.net/
This project has a number of packages including servers (slaves), clients (masters), and libraries which you can incorporate into your own custom
applications. It also includes a soft logic library which will let you run programs written in IL (Instruction List). This will (within a month or so) be incorporated into MBServer to make a complete stand alone soft logic system.
It presently supports Modbus/TCP and a Modbus-like web service as well. Modbus/TCP is a very common Ethernet based industrial protocol, and of the
major protocols is the only non-proprietary one.
All the packages are written in Python and developed on Linux (they will also run on MS Windows though, and probably Mac OS/X as well). MBServer also needs Twisted, but Twisted is in the standard Ubuntu repositories so you can install it with Synaptic with a couple of mouse clicks.
If you have any more questions, let me know and I will be happy to answer them.
Posted by Curt Wuollet on 20 August, 2008 - 1:43 am
Google Comedi, it will let you use a DAQ card from various sources to control things. The only problem is most cards have ttl level outputs. I designed and built a card to give you 24V levels from a commodity DIO48 card. But you can get drivers for some relay cards and I think I heard about drivers for Opto-22 racks also. If you want a soft PLC on Linux check out the MAT/PLC project.
cww
Posted by pvbrowser on 20 August, 2008 - 1:55 am
You might have a look at http://pvbrowser.org
It is a HMI/SCADA framework.
Supported protocols:
- Modbus (Serial Line and TCP)
- Siemens TCP
- Siemens PPI
- Ethernet_IP
- EIBnet/KNX
- OPC XML-DA
- PROFIBUS
- CAN
Posted by Juan Jose Denis Corrales on 20 August, 2008 - 11:50 pm
We are engaged in building an easy way to control a plant with a Linux PC, Modbus/TCP modules and python. We call it likindoy-RTU.
We'll be testing and documenting our likindoy-RTU in September. Follow our efforts or join us if you wish at the project's web site: http://www.likindoy.org
Advertisement
