- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
the proper order then why can't he?
www.control.com/rss/
The query message is a 6-byte string(without CRC) that I send to the RS232 API functions. for example:
//It builds the packet
void modbusBuildQueryPacket(st_modbusQuery modbusQuery, unsigned char *queryPacket)
queryPacket[0] = modbusQuery.address;
queryPacket[1] = modbusQuery.function;
queryPacket[2] = modbusQuery.startAddressHI; //high order
queryPacket[3] = modbusQuery.startAddressLO; //low order
queryPacket[4] = modbusQuery.countHI;
queryPacket[5] = modbusQuery.countLO;
//function to send the query
int modbusFunctionSend(st_modbusQuery modbusQuery, unsigned char hasCrc, unsigned char *queryPacket)
modbusBuildQueryPacket(modbusQuery, queryPacket);
if (modbusSendQuery(queryPacket, MODBUS_QUERY_LENGTH, hasCrc) < 0)
return -1;
return 0;
//and now the function that writes on the rs232 //driver
int rs232_msgSend(unsigned char *buffer, int size)
DWORD dwBytesWritten = 0;
int i, status;
int bytesWritten = 0;
printf("Size: %d\n\r", size);
fflush(stdin);
for(i = 0; i < size; i++) {
status = WriteFile(Hcom, &buffer, sizeof(char), &dwBytesWritten, NULL);
bytesWritten += dwBytesWritten;
printf("Status: %d; bytesWritten: %d\n\r", status, bytesWritten);
if (!status)
return -1;
return bytesWritten;
So, I actually write at least 5 times on the driver to send the message. I can do at this way, or I need to write a single message of length 5?
My CLP receives the message, but it isn`t answering. (Yes, I double checked the address and functions that it supports)
If anyone have a better implementation idea, or suggestions, or an idea of where my mistake is, please send me an email.
davidcemin @ gmail.com
check using another pc to varify the data being sent. It's possible you maybe to fast for the end device. Is there handshaking enabled xon xoff
glengillisnaz @ hotmail.com
Ideas?
The one I used is from Calta.(http://www.calta.com/)
It is a pretty handy tool to diagnose MODBUS problem. You can try other similar products. A lot of them are free.
Peter Hao
Eric
www.icpdas-usa.com
- Joint initiative to explore cellular solutions for industrial automation
- Post-Katrina: Rugged fiber-optic network is set to report through hurricanes
- Networks: EtherCAT industrial Ethernet protocol for motion control, Power over Ethernet
- ODVA announces new editions of CIP network specifications and testing of Ethernet/IP products
- Molex releases new connection system and expanded line of Ethernet switches
- Siemens expands IP65/67 distributed I/O line
- Synapse Wireless California Eastern Laboratories form partnership
- Prosoft introduces wireless 802.11g point I/O adapter and appliance transaction manager
- Belden releases new continuous flex Ethernet cables
- Easier startup: Petropiar Oil Refining Facility is 2008 HART Plant of the Year
