- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
use to oneself.
-- Oscar Wilde
www.control.com/rss/
You can use
http://libnodave.sourceforge.net/index.php
if you only need a communication library
or
http://pvbrowser.org
if you also need a visualization for that.
Sorry, but the Siemens S7-200 DOES use MODBUS, and there is a perfectly good MODBUS master available in the libraries, I have several projects running Remote IO via MODBUS from S7-200s.
The latest MODBUS Master library is v1.2 and you may use either port, MODBUS Slave is available as v1.0 only on Port 0
Marc Sinclair
http://s7-200.germainesystems.eu
http://www.industry.siemens.de/IT4Industry/EN/solution_servic es/SIMATIC_Addons/proto_mod.htm
But I think that costs extra money.
The native protocol of Siemens PLC's is NOT open and has been reverse engineered by
for example.
Within http://pvbrowser.org we make use of that.
The above modbus solution from Siemens is for Modbus/TCP only. If somebody knows a modbus solution from Siemens which works with an RS232/RS485 converter please let me know.
Yes MODBUS, using the s7-200 library will work, but try Libnodave, that might
have the functionality you need.
You will need the programming lead (RS485-RS232) to connect to a standard PC
serial port
Marc Sinclair
http://www.germainesystems.eu
Thank you,
David Adams
Application Engineer
CONTROL PRODUCTS
dadams@controlproductsinc.net
334-567-2017 office
334-567-8614 fax
334-303-9499 cell
Try to prove the libnodave.
But according to the commentary by David Adams, I feel good option, but how do I do with communication to Simatic Panel?, taking into account that I leave a free port for maintenance and scheduling.
Thank you
Juan Espejo
You have a few options. Feel free to contact me at
dadams @ controlproductsinc . net and I will try to help further.
David Adams
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
- Process modeling: Spreadsheets support multiphase flow simulation
