Remote battery operated pressure transmitter
DPhair
Here is the opportunity:
We have a chamber in the middle of nowhere that has an altitude valve, and we wish to monitor the pressures on the upstream and downstream sides.
The information will be sent by a cellular modem to the water plant.
We need two battery operated pressure transmitters
(capable of operation continuously for one or two months between replacement of batteries) with a range of 0 to 300 PSI.
Any suggestions as to suppliers?
Dennis
Dennis.phair @ hatchmott dot com
R
Rosemount have a range of transmitters that put out a voltage instead of current for low power applications.
Another possibility is to just sample the pressure, e.g. every 5 minutes power up a regular transmitter, wait for the signal to settle, then power down.
Roy
