Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
MESSAGE ACKNOWLEDGED -- The Pershing II missiles have been launched.
www.control.com/rss/
Our annubar, which is installed in cooling water line, was broken. Line fluid is cooling water, 52" size & 2000Ton/h. I should calculate proper thickness of annubar prob.
Does anybody have the same experience?
You have an inserted hollow stick, with holes in it, in a 52" diameter pipe, flowing 2000 T/h. Did it bend flat in the direction of flow? Or did it break off? Either way, I bet you have been a victim of "water hammer." Water is incompressible, and closing a valve too quickly can send a "hammer" pressure wave down the pipe. Water hammer can be 5 to 10 times the static pressure in the pipe... and can burst pipes and damage inserted components like multi-port pitot tube flow meters and thermowells, etc.
Some of us may be old enough to remember seeing the old Johns-Manville training film on avoidance of water hammer. It certainly made a believer out
of me.
Walt Boyes
Editor in Chief
Control and Controlglobal.com
www.controlglobal.com
Mailto:wboyes@putman.net
Read my blog SoundOFF!! At www.controlglobal.com/soundoff
of me.
Walt Boyes
Editor in Chief
Can't get the flow to fit with the pipe id. The given flow seems very low. Can you check that it's correct?
Anyway you can study water hammer on YouTube:
http://www.youtube.com/watch?v=zAG45ILN7Kk
/Ulf
/Ulf
Hello sir. The Annubar is manufactured by Dieterich Standard, a division of Rosemount. I am an applications engineer with the company, and would like to inquire if you have spoken to anyone within Rosemount. If not and you would like to discuss the broken sensor further, please contact me at derek. ott at emerson. com
Thank you,
Derek
Thank you,
Derek
There could be various reason for breaking of the ANNUBAR in the process line. A detailed study is required before commenting on the reason. Consult the supplier or the manufacturer. Most of the time the failure of sensor is not due to the construction or manufacturing issue but it is related to installation or process conditions.
Related articles from Control
Engineering magazine- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Here's what you need to know about controls, says Automation Federation, U.S. government
- Electrical product safety: Are testing labs needed or is a supplier's declaration enough?
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
