I did a brief search in this forum but didn't find quite what I'm looking for.
I need an overview of Modbus RTU and what sets it apart from Modbus/TCP or any other Modbus protocol for that matter.
I've scoured the internet but came up pretty much empty except for a few lines that mention that RTU is in Binary as opposed to ASCII. I'm looking for more depth than that.
So if you've found a good overview somewhere on the net, please share. Any help would be appreciated.
You can find the documentation for MODBUS RTU in the Schneider website. Or I can send you docs for the MODBUS RTU provided youe supply me with your email address.
Thanks,
JM
Thanks,
JM
http://www.modbus.org/ would be a good place to look for information.
Good luck,
Mark
http://www.peakhmi.com
Good luck,
Mark
Look at Modbus TCP and RTU protocol specifications
Also:
http://www.simplymodbus.ca/TCP.htm
Also:
See http://www.simplymodbus.ca/FAQ.htm
Give this link a try.
http://www.lammertbies.nl/comm/info/modbus.html
You can download the protocol specs here:
http://www.modbus.org/tech.php
If you need some help on implementing a Modbus network I might be able to assist if you provide me some details on your application goals.
Thanks everybody for the replies, this should be more than enough information to go on. If there's anything else I need, I'll be sure to come back. I'm surprised at the amount of help I've received about this.
Newton's Fourth Law: Every action has an equal and opposite satisfaction.
