Fiber optic system versus Masterbus300
P
pk
Hi friends.
We want to change our Masterbus 300 cable with fiber optical cable. What we need is a converter/switch for converting the fo signal and one converter at communication card. But I want some more details...
What kind of converter can be used? Please help me.
Bryce Gillan
Hirschmann Mice MS2108-2 with the appropriate media module according to the type of fibre you install, e.g. MM2-2FXM3/2TX1 gives you 2 x 100BASE-FX, 2 x 10/100BASE-TX,
Install a 10/100BASE-TX transceiver onto the DCS comms card AUI port with UTP cable to a the Ethernet switch.
Thank you friend,
But can you tell me in some more detail please? We need some converter, like in Siemens we use OLM converter for converting optical signal to Profibus. Also then we need some converter on the communication card at AUI port.
