- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
Statement presented by a human and accepted by a computer in
such a manner as to make the human feel as if he is in control.
www.control.com/rss/
Is it possible to get a differential pressure gauge that measures in terms of flow in m3/hr or are only ones with a span of sqrt(0-10) commonly used?
sshad at engro. com
Custom scales are possible but are expensive because they are made to order and the cost of redrawing the scale manually is often more expensive than buying a powered unit.
Powered indicators are normally standard (off the shelf) items that can be configured to the flow.
It is not easy to recommend a manufacturer of a gauge, because you did not give us the static line pressure. This will change the recommendation.
I trust this helps.
Malvern
www.coulton.com
The advantage of using a DP cell is you can get the square root function and a digital display. You don't need anything else but a power supply (12-24 VDC) and indicating DP cell. You will likely find that a DP cell is cheaper than a quality DP gauge with special scale.
Roy
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Digital manufacturing: Autodesk Inventor shows component interactions
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
