Please help me out here. I was looking for a type of PLC that has the best compatibility with the ff:
Analog input: 15 pts.
Digital input devices:
* Pressure switch-2
* 3-point switch-3
* Limit switch-6
* Push button switch-3
* 2-position switch-1
* Level switch-4
Digital output devices:
* Pilot almp-17
* Solenoid-1
* TDS monitor-1
* Ball valve-3
* Motor starter-4
* RH meter-4
* PH meter-1
* Motor pump-2
Please attach links where I can view prices of your suggested PLC. Just in case you know sites. Thank you very much!!!
Can I ask another one? Is Versamax PLC ok to use on the above conditions that I gave? Thanks again!
* Pressure switch-2
* 3-point switch-3
* Limit switch-6
* Level switch-4
* Pilot almp-17
* Solenoid-1
* TDS monitor-1
* Ball valve-3
* Motor starter-4
* RH meter-4
* PH meter-1
* Motor pump-2
