- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
truth without lying.
www.control.com/rss/
PC
Regard
benjas
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Basically, this is a 20Amp-Turn Current Transformer (CT) sensor that steps down the AC current and then full wave rectifies the output to create a dc current for interfacing with dc current input circuits. For 5A inputs, you simply put 4 turns thru the sensor to create 20 "amp-turns.". The dc current output from the sensor can drive a load of about 75 ohms or less. The sensor looks like a small donut and is about 1 inch in diameter.
There are many technical benefits to using a CT sensor like this if it will work for you. Accuracy is also better than 0.5 percent, Otherwise, there are op-amp circuits used for full wave rectifing of AC voltages that can be created by dropping AC currents across a resistor of very low ohms. Another technique can involve using Hall Effect sensors that yield dc outputs.
Here are two links to Acromag's Model 5020-350 AC Current Sensor Application Note:
http://www.acromag.com/pdf/AC_Current_Sensor_5020_350.pdf
h ttp://www.acromag.com/supi_application_notes.cfm#isolators
If you have any questions or need more info, just let me know or contact Acromag.
Donald Lupo
Director of Marketing and Sales
Process Products
Direct: 248-295-0860
Cell: 248-787-3882
sales@acromag.com
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Digital manufacturing: Autodesk Inventor shows component interactions
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
