Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
It has been said that man is a rational animal. All my life I have
been searching for evidence which could support this.
-- Bertrand Russell
-- Bertrand Russell
www.control.com/rss/
We are currently measuring gas flow in our process. Now there is a need for us to represent the total amount of gas used in Nm3/h. I understand that this is also affected by the gas temperature and pressure. I need the formula to get gas quantity when measuring flow.
1. Find out the pressure and temperature conditions used for the "normal" state - N means "normal". Convert to absolute units. These are Pb and Tb respectively - b = base.
2. Also convert the actual pressure and temperature to absolute units. These are Pa and Ta respectively - a = actual.
3. Then volumetric flow at base conditions = volumetric flow at actual
conditions x Pa/Pb x Tb/Ta.
The "Normal" pressure will probably be 101.325 kPaA but the temperature could be 0 degC or 15 degC or 20 degC... so you need to check.
Bruce
Bruce
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
