member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
A LISP programmer knows the value of everything, but the cost of
nothing.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Forum department...
Modbus Communication on RS-232
Communications systems and equipment. topic
Posted by Emin Ceyhan on 17 October, 2008 - 3:01 am
I have a weight controller with RS-232 protocol. This controller does not support Modbus, only RS-232. I want to transmit the data to a Modbus TCP device. How can I do this? Flow chart is like this:
Weighting->Converting analog output->To RS-232 protocol->To Modbus/TCP device
I need to achieve the last part. If it is not possible to convert directly to Modbus/TCP, I can accept that firstly a Modbus RTU than a Modbus/TCP convert.
Emin
Posted by Jerry Miille on 17 October, 2008 - 4:44 pm
You could use Omnii-Comm with Ethernet to do this for you.
http://www.miille.com/266-P00-Ethernet.pdf
Thanks,
< br>Jerry Miille
Miille Applied Research Co., Inc
Posted by pvbrowser on 18 October, 2008 - 4:35 am
You can use this gateway for example
If you have a computer anyway,
you can use it's serial interface and network port and do it in software.
We provide this within our project
http://pvbrowser.org
For serial communication use:
http://pvbrowser.de/pvbrowser/sf/manual/rllib/html/classrlSeri al.html
For implementing the Modbus/TCP server use:
http://pvbrowser.de/pvbrowser/sf/manual/rllib/html/classrlModb us.html
Thus you can handle any protocol that is run on RS232.
Posted by Darrin Hansen on 20 October, 2008 - 11:18 am
It's not clear from your desired configuration whether you want your Modbus/TCP device to actively transmit the data (i.e. act as a client) to some other Modbus TCP slave (server), or whether you want your Modbus/TCP portion to just passively sit there until a Modbus/TCP client requests the I/O data from it. Most Modbus/TCP devices are servers (the second scenario).
If that is also your scenario, then you can look at the ICC ETH-200 gateway, which supports Modbus RTU (master and slave) and Modbus/TCP (server).
http://iccdesigns.com/Merchant2/merchant.mv?Screen=PR OD&Store_Code=ICC&Product_Code=10570
Darrin
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
