Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Beware of the Turing Tar-pit in which everything is possible but
nothing of interest is easy.
www.control.com/rss/
Ike damaged a portion of my modules and wiring, which of course was salt water. The plant turned them back on, and it shorted the power supply first. If I replace the supply, will it short again on other components? The power supply didn't even get wet, the rest did get wet. Please reply to rausone1 at aol. com
I would expect you to have a major problem with any electronics exposed to salt water. Perhaps a solution might be to rinse all the components with demineralised water then dry them well before powering up. There must be lots of experience in your area.
Good Luck.
Roy
Good Luck.
Roy
I would suspect that the short is somewhere in the part of the system which got wet. There could be multiple shorts. Also, the part which shorted out could be further damaged by the short itself.
Depending on the hardware, you may have to clean the affected components with fresh water and then dry thoroughly, or you may have to replace them. For electronics, I would replace them. For other parts, it may be cheaper (in terms of labour) to replace them than to disassemble and clean them.
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
