Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
You're not drunk if you can lie on the floor without holding on.
-- Dean Martin
-- Dean Martin
www.control.com/rss/
I have a Fanuc 90-30 PLC with CPU 363. On its RS485 port (on CPU), one local operator interface (XOR's Tline) is alredy connected. I need to connect a PC to RS232 (RJ11) port on the CPU 363 to obtain various register and coil values using Modbus RTU protocol.
I have gone thru various google searches but still not clear what exactly is required to achieve above aim. Do I need to do any PLC programming etc like COMMREQ.
I have been dealing with different PLC's in the past. For making a PLC as RTU slave, in my opinion all you require should be to tell its CPU what are the comm parameters like baud rate, parity, data word length, stop bits and parity besides defining station address.
Can someone tell me all steps involved.
Thanks and Regards.
My email ID is vkaggarwal2@yahoo.com
Thanks and Regards.
The last time I used Modbus on the 90-30 I used a Horner Modbus card although this was as the master communicating to slave instruments. I have used Intouch as the SCADA and connected straight to the port using the SNP IO server, it is possible to use Kepware as the IO server which will use either CCM or SNP. Using something like Kepware means the IO server will just read/write to the registers of the PLC without any PLC software.
Kevin
Kevin
You can specify the parameters in the CPU configuration: Baudrate, Flow Control, parity, station address.
Joern
Joern
Thanks Joern. Does it mean nothing else need be done except hard configuring the RS232 port?
VK Aggarwal
VK Aggarwal
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
