Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
If I traveled to the end of the rainbow
As Dame Fortune did intend,
Murphy would be there to tell me
The pot's at the other end.
-- Bert Whitney
-- Bert Whitney
www.control.com/rss/
I would like to make an automatic control of a pressure gradient in a capillary, which is needed to get molecules from a furnace to a mass spectrometer. Could you help me how can I make an automatic connection of valves? I always have to manually adjust them to get right pressure in a capillary. I have to deal with 2 different pressure conditions in the furnace:
1. atmospheric pressure (40 mbar in a capillary)
2. 40 mbar (1.10-3 mbar in a capillary)
(see the scheme: http://www.berger.euweb.cz )
Both conditions needs to be treated by adjusting valves to regulate a vacuum pressure in a capillary made by rotary vacuum pump. This pump helps to reach a pressure gradient between the furnace and the mass spectrometer equipment.
Actually I think that the valve close to pump is the one which should be regulated. The valve close to the furnace should be probably changed for pressure transducer sending an informatin to the valve by the pump.
Could you make any suggestion how I could make an automatic valve switching for both pressure conditions?
Thank you for any helpful notes.
I assume you have some form of pressure transmitter to measure the pressure and your GC runs on a PC. I have attached a link to a valve actuator vendor.
http://www.hanbayinc.com/
This company makes small actuators that fit the tiny instrument valves. Some of these have a serial interface to work with a PC. If you fit one to the valve you presently change by hand you may be able to automate it using the GC's PC. I think Hanbay would also be helpful in recommending a software package.
Hope this helps,
Roy
Hope this helps,
Roy
Thank you very much, I think that I can order some valves with actuators on that website.
Stan
Stan
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
