Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
California is a fine place to live -- if you happen to be an orange.
-- Fred Allen
-- Fred Allen
www.control.com/rss/
Has anybody established communication between Omni Flow Computer 6000 and Honeywell TDC-3000 through HPM-Serial Interface?
The OMNI Flow uses the Enron Modbus protocol and the HPM interface of the TDC does not support Enron Modbus. You will need to bridge the data between Enron Modbus and regular Modbus to get the communications established. You can use Kepware's KEPServerEX and Modbus Driver suite with LinkMaster to do the bridging. For Details contact Kepware Technical Support or Kepware Sales.
Fred Loveless
Senior Applicaiton Engineer
Kepware Technologies
http://www.kepware.com
Fred Loveless
Hi there,
I work for a company called HMS and we manufacture, among other things, gateways. We have a gateway that can be configured to poll one register and handle the 32 bit response. On one side of the gateway, it will act as a standard Modbus RTU slave device and the other side can be programmed.
For more information, go to:
http://www.anybus.com/support/support.asp?PID=317&ProductTy pe=Anybus%20Communicator
or send me an email at:
support at hms. se
/Pat
support at hms. se
/Pat
Related articles from Control
Engineering magazine- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Signal conditioners support universal input, feature detachable display
- Motion control: Omron selects EtherCAT as its next motion bus system
- Wireless: Adoption trends in factory automation
- Tutorial: Instrumentation / DCS integration languages, part 2: FDT
- Connectivity: Embedded LAN module with minimum programming
- New 1-1/8 in. M23 connectors provide 19 pins
- Hatching distributed automation architectures
Subject to its Terms of Use.
