Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
I see a good deal of talk from Washington about lowering taxes. I hope
they do get 'em lowered enough so people can afford to pay 'em.
-- Will Rogers
-- Will Rogers
www.control.com/rss/
We have Mark V controller. We have switched off the printer as it gives unnecessary logs. How can I see the contents in the print queue by <I> computer? Can I delete part of that and print only the alarms I need?
Thanks.
Thanks.
It's not possible to view the contents of the print queue.
If you have an <I>, exit to a command prompt and at the command prompt, type:
LOGGER FLUSH
If you have an HMI, open a command prompt window and type:
LOGGER
and select 'Flush'.
This command will delete the contents of the print queue (which can't be viewed on an <I> or an HMI).
On an <I>, if you type
LOGGER /?
you will get a help screen with some information about the other options of the Logger utility.
On the HMI, the Logger applet will provide some information about the functions available.
One thing to note: Logger cannot be easily set to execute each time the <I> or HMI is started.
You haven't said what is unnecessarily printing; is it nuisance Diagnostic Alarms? Is it nuisance or dithering Process Alarms? Is it SOE or EVENT data?
LOGGER FLUSH
LOGGER
and select 'Flush'.
LOGGER /?
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
