Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
For those who like this sort of thing, this is the sort of thing they
like.
-- Abraham Lincoln
like.
-- Abraham Lincoln
www.control.com/rss/
from the Forum department...
Least count of flame detector in GE FRAME 9E gas turbine MARK V control systemL28FDAL28FDB, L28FDC, L28FDD... These logics are becoming 1 when the FD reaches some specific counts which are defined by GE. Could anyone tell me about this?
In the flame detector monitor, when the count is less than 16, the logic will become 1.
Please very it whether it is less than 16 or greater than 16. I don't think less than 16 is correct.
To ascertain the threshold of your flame detector logic, you need to check Screen 3/5 of TCEA definitions within your IO Configurator. The values in here are 1/16 so a value of 1 in here is a count of 16 as per the previous reply.
Hope this helps.
Martin
Hope this helps.
Martin
Thank you so much Mr. Martin.
I hope this but that first response was the logic such as L28FDS, L28FDB, L28FDC, L28FDD says that it becomes 1 when the count is less than 16. If it is so our turbine can't be running. It should be greater than 16. It might be typographical error.
Have you read Section. 7.8 of the the Mark V Application Manual, GEH-6195?
I read but he hasn't given any clear threshold value. Instead he has given as THRESOLD HIGH & LOW ..._HI[0] to _HI[7], -LO[0] to -LO[7]. How can find the threshold in terms of count? Please help me.
I'm confused about your confusion. The threshold value is the value of counts for the flame detector input above which the associated logic signal will be a "1". There were some versions of TCEA PROMsets that implemented a high- and low threshold value which could be activated through software, primarily for DLN-I applications.
So, for FD_INTENS_1 if the threshold value in the I/O Configurator is set for 16, then when the counts of the input exceeds 16 L28FDA will be set to a logic "1".
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
