Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Absurdity, n.:
A statement or belief manifestly inconsistent with one's own
opinion.
-- Ambrose Bierce, "The Devil's Dictionary"
opinion.
www.control.com/rss/
I am working on a revamp project. The old RTUs have built-in FSK modems with the following specs:
1. Mode: Half Duplex
2. Data Rate: 1200 BPS asynchronous
3. Data Bits: 8
4. Parity: None
5. Modulation: FSK
6. Carrier Frequency: 1200 Hz, Space 2200 Hz.
7. Input Impedence: 20 Kile Ohm unbalanced
8. Output Impedence: 600 Ohm balanced
9. RTS to Transmission Delay: 10 ms
10. Sensitivity: -35 dB
11. PTT signal: Isolated, solid state switch
Can anyone suggest to me a modem that I can use which has the above mentioned specifications?
Guys I need this quick.
Thanks in advance.
3. Data Bits: 8
4. Parity: None
5. Modulation: FSK
Thanks in advance.
The MARC 366-101 matches most of the specifications you list. The major differences are that we only spec down to -25 dB and the PTT output is a contact closure. You did not specify the power requirement but our modems are 24 VDC powered. Link to a data sheet here:
http://www.miille.com/din366-101.pdf
and the manual here:
http://www.miille.com/366101_Users_Manual_Rev_2.pdf
My contact information is on the data sheet.
Thanks,
Jerry Miille
Miille Applied Research Co., Inc
Thanks,
Jerry Miille
From those specs, I think the old RTUs have Bell 202T leased-line telemetry modems. I've used these in systems which had one master site and several remote sites. We tried several before settling on the Control Microsystems model 5902. The 5902SAF version has a 120vac adapter and a full-duplex adapter board that keys the carrier on data instead of using the RTS/CTS lines in the RS-232 port.
Related articles from Control
Engineering magazine- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Signal conditioners support universal input, feature detachable display
- Motion control: Omron selects EtherCAT as its next motion bus system
- Wireless: Adoption trends in factory automation
- Tutorial: Instrumentation / DCS integration languages, part 2: FDT
- Connectivity: Embedded LAN module with minimum programming
- New 1-1/8 in. M23 connectors provide 19 pins
- Hatching distributed automation architectures
Subject to its Terms of Use.
