member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
Give me a Plumber's friend the size of the Pittsburgh dome, and a place
to stand, and I will drain the world.
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Forum department...
Single Phase to 3 Phase for Battery Charger
Posted by DIPNDAP on 29 October, 2008 - 1:25 am
I have a heavy duty three phase battery charger for my forklift, but I only have single phase power available. The charger is 3PH 208/240/440V about 20/18/9 amp input. My power is 120/240V 200 amp.
I was told I "may be able" to connect the 3 inputs to the charger (2 of the 110/120V legs to each of 2 of the leads and 1 lead to the other leg). I have heard this may be "possible" on a resistive load (stove, heater, etc.), but would probably require more on transformer equipment (battery charger, welder, etc.). The charger does have indicator lights, meter, taper back charge rate sensor, etc. Any help would be appreciated.
Posted by Curt Wuollet on 30 October, 2008 - 1:28 am
I wouldn't bet on that. Even for a battery charger, a polyphase rectifier is designed for the conduction angles and current distribution that you get with 3 phase power. Unbalancing it will greatly increase ripple and diode currents to get the same output. An inverter as is used for machine tools might work, but it might be cheaper to sell the 3 phase charger and buy a single phase charger.
cww
Posted by Robert D. Wagner on 30 October, 2008 - 2:18 pm
Check out single to 3-phase converters at phase-a-matic.com, also available
from surpluscenter.com
Robert D. Wagner, P.E.
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
