member
passwd
remember me on
this computer.
- join now -
Jump to a Date
Select a topic of interest:
...and press:
Control.com Stuff
The world's as ugly as sin,
And almost as delightful
-- Frederick Locker-Lampson
www.control.com/rss/
Select a Page Style
- BluFu
- Classic
(cookies required)
from the Electrical department...
Loop resistance and capacitance voltage transformers
Engineering and workplace issues. topic
Posted by sunny on 29 October, 2008 - 7:24 am
1. To measure loop resistance of small motors rated in KVA, we simply use a multimeter to get required results while for large motors/equipment rated in MVA we have to use a test set through which we apply some current & get the results. Why doesn't multimeter work there?
2. What is the purpose of capacitors in capacitance voltage transformers?
Moreover, what is the difference between a PT & CVT?
Posted by Roy Matson on 30 October, 2008 - 4:14 pm
I will try to answer part 1.
The resistance of your large machine is very low so a multimeter's Ohm scale isn't accurate enough. By passing a relatively high current and measuring the voltage drop you can calculate very low resistance down to the micro-Ohm range. This method is sometimes called a "Drop Test".
For example, if you pass 100 Amps through a pair of contacts and measure 0.1 volt across them the contact resistance is 0.1 / 100 = 0.001 Ohms.
Roy
Above articles copyright 2009 Reed Business Information. Subject to its Terms of Use.
Internet Explorer 6.0 Fix
Advertisement
