Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Others will look to you for stability, so hide when you bite your
nails.
nails.
www.control.com/rss/
Dear Friends,
I have two PLCs:
1. Siemens S7 400 series
2. ABB AC800
I want to communicate between these two PLC through optical fibre cable. What will be the requirements?
1. Hardware requirement in both PLC systems
2. Software requirement in both PLC system
3. How to join two optical fibre cables
Your early response will be appreciated.
I have two PLCs:
2. ABB AC800
There are many methods for the communication. The two most common methods would be:
1. Use serial interface, using Modbus (good)
2. Use Profibus-DP interface (better).
In case of serial interface, you will require the serial cards on both AC800 side and S7-400 side. Additionally, you will require Modbus drivers for both sides.
For optical fibre connection, you can use the Siemens OLM (Optical Link Modules). It's good to find out what is needed, please try looking at the websites of the vendors.
Best Regards,
Shahid Waqas
shahid. waqas at gmail. com
Best Regards,
Shahid Waqas
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
