Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
What I want is all of the power and none of the responsibility.
www.control.com/rss/
I am attempting to establish 485 Modbus comms to five Powermonitor 3000 units. I believe I have good comms to the devices as I can poll the real time clock for good data. However the actual current/voltage data in float format doesn't match the display data. Has anyone ever come across a similar problem?
This is not unusual. Since Modbus does not define a floating point data type there are all sorts of ways to send the four bytes of a 32-bit floating point number. You will need a way to get the bytes out of the Modbus message into the proper order. If you are writing your own code then this should not be a problem. If you do not have that option, you will need an external device to do it for you. Our Omnii-Comm product has an option for this.
http://www.miille.com/din266-p00.pdf
You may contact me at the numbers listed on the data sheet for more information.
Jerry Miille
Jerry Miille
Related articles from Control
Engineering magazine- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Signal conditioners support universal input, feature detachable display
- Motion control: Omron selects EtherCAT as its next motion bus system
- Wireless: Adoption trends in factory automation
- Tutorial: Instrumentation / DCS integration languages, part 2: FDT
- Connectivity: Embedded LAN module with minimum programming
- New 1-1/8 in. M23 connectors provide 19 pins
- Hatching distributed automation architectures
Subject to its Terms of Use.
