Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Reflections on Ice-Breaking"
Candy
Is dandy
But liquor
Is quicker.
-- Ogden Nash
Candy
Is dandy
But liquor
Is quicker.
-- Ogden Nash
www.control.com/rss/
I have a plant transfer function Gp(s) = 4/(s*(s+2)) The denominator has a degree 2. When I convert this to discrete time using the residual method and a Zero Order Hold, I multiply the denominator by another s so the degree is now 3. Using the residual method formula in the notes, I get a Gp(z) = 4.2749/(z-0.8187)
I'm supposed to use Ragazzini's method to design a lead compensator for this system. The pole of this Gp(z) is clearly not outside the unit circle. So there is no need to eliminate any poles/zeros in the F(z) function. I'm not sure how to continue with this. In all my previous lecture examples, there has always been an unstable pole/zero in the Gp(z), which we need to cancel out by inserting a new pole/zero in the F(z) to compensate. Now that the only pole is z=0.8187, and it's stable, is it safe to say that we don't need to cancel any poles out?
I suspect that maybe I'm not applying the Residual method correctly to convert from continuous to discrete time. Remember, I have to apply a ZOH first. The way I did it was I multiplied Gp(s) by (1-exp(-s*T))/s . Then I separated the (1-exp(-s*T)) and that becomes (z-1)/z . The extra s is multiplied with the denominator of the original Gp(s), so now I am looking for the z-transform of (4 / (s^2)*(s+2))), but the original Gp(s) denominator was just s*(s+2).
Moin ywk...
moin all,
Z-Transforming a second order continuous system like your
Gp(s) = 4 / ( s*(s+2) )
will always result in a second order discrete system.
Additionally a continuous system with an integral part as yours will
always keep the integral part after Z-transformation, i.e. will have a pole at z=1.
When using 0.1 (sec) as sampling time T a get a discrete transfer
function of
Gp(z) = ( 0.018731*z^1 + 0.017523 ) / ( 1*z^2 - 1.8187*z^1 + 0.81873 )
with
zeroes =
-0.935525 + 0.000000i
poles =
0.818731 + 0.000000i
1.000000 + 0.000000i
This has the pole you mentioned and additionally the required pole at 1 and a zero at z=-0.935525.
BTW, you cannot cancel an unstable pole, neither in the s-domain nor in the z-domain.
Best regards,
Friedrich Haase
moin all,
function of
with
zeroes =
poles =
Best regards,
Friedrich Haase
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Here's what you need to know about controls, says Automation Federation, U.S. government
- Electrical product safety: Are testing labs needed or is a supplier's declaration enough?
Subject to its Terms of Use.
