Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
Of what you see in books, believe 75%. Of newspapers, believe 50%.
And of TV news, believe 25% -- make that 5% if the anchorman wears a
blazer.
blazer.
www.control.com/rss/
We have three MarkVI for our gas turbines. We have observed that one of the MarkVI "R" processors gets restarted/hangs frequently--once a day. So we tried first with replacing VCMI card but still the problem persists, so now we're trying to replace UCVE card. As per GE System VOl-1 guidelines, we need to format the flash disk and reprogramme (Set IP Address) using COM1 on the UCVE and Serial Loader application.
We are formatting the flash disk using flash disk reader from our HMI. While using Serial loader application on COM1, we get following message:
Command: Configure TCP/IP
Cycle Powe ON the target (; we power on the rack however is not mentioned in manual)
Error: Timed out waiting for login:
Command aborted with errors...
Please suggest the procedure to replace UCVE and then load flash programme and set up UCVE TCP/IP address.
Dharmesh
Dharmesh
The last time I had to do this we still used the. I got a text capture from it and hope it helps. I do pretty well, but at times some stuff it just foggy. The capture is long, as I cycled power several times.
You need the GE supplied small 9 pin serial cable.
Using:
HYPER TERMINAL
SETTINGS:
COM1
PORT SETTINS:
9600
8
None
1
Xon/Xoff
Settings
VT100
Tel net terminal ID: VT100
Backscroll buffer lines: 500
ASCII Setup:
Cursor - Underline
Charactor set - ASCII
ucinfo
Bi os versi on
Fl ash versi on
IP name
IP address
IP broadcast
IP netmask
IP router
payson capture 072704.TXT
~N/A
~V070100C OCT 2001
~H1-s
~192.168.101.45
~192.168.101.255
~255.255.255.0
~not specified-default
External online load in progress ***
SYSERR sys loader (91): EGD net record 11733 not allowed in online loads
proc output to serial port 3f8 at 9600 baud
Press RETURN key within 2 SECONDS to ABORT uc2k startup
'platform' found - NORMAL startup
cd /usr/bin
platform -u &
platform V02_0l-01C - Dec 03 2003 17:03:08
UC2K-Start: platform Registration After 5 Seconds.
en1: flags~8863<UP.BROADCAST,NOTRAIlERS,RUNNING,SIMPlEX,MUlTICAST>
1net 192.168.101.45 netmask ffffffOO broadcast 192.168.101.255
cd /usr/bin
sys &
MARK VI Runtime version V05_02_04C
sys_mk6 v05_02_04C - Dec 03 2003 17:04:55
V070100C OCT 2001
ucidle
bgnd
heartbeat
diag
1Ogl n: sdi
adl
diag_alarm
v05_00_01C - Dec 03 2003 17:00:52
v06_05_03c - Dec 03 2003 16:59:00
v06_04_01C - Dec 03 2003 17:02:32
v06_00_05c - Dec 03 2003 16:59:16
V05_02_03c - Dec 03 2003 17:01:48
V07_00_10c - Dec 03 2003 17:03:02
VOl-00_01C - Dec 03 2003 17:03:17
dpm_mgr vOl-10_01c - Dec 03 2003 17:03:28 - ECl 3.5 beta-D
SYSWARN dpm-mgr: Dual port initialization timeout, check clock source.
SYSERR Sys expander (209): DPM manager died prior to registration (No such process).
SYSERR sys loader (209): Mark VI Rack record 11700 load failed
SYSERR sys loader (209): Application file load failed with error 209
******* Mark VI Initialization completed *******
cd /usr/bin
platform -u &
platform v02_0l-01c - Dec 03 2003 17:03:08
uc2K-Start: platform Registration After 5 seconds.
Page 1
en1:
fla9s=8863<UP, BRoADeAST,NoTRAIlERS, RUNNING,SIMPlEX,MUlTleAST>
cd /usr/bi n
sys &
MARK VI Runtime Version V05_02_04e
sys_mk6 V05_02_04e - Dec 03 2003 17:04:55
v070100e OCT 2001
ucidle
bgnd
heartbeat
dia9
1Ogl n: sdi
adl
di ag_al arm
v05_00_01e - Dec 03 2003 17:00:52
v06_05_03e - Dec 03 2003 16:59:00
V06_04_01e - Dec 03 2003 17:02:32
v06_00_05e - Dec 03 2003 16:59:16
V05_02_03e - Dec 03 2003 17:01:48
v07_00_10e - Dec 03 2003 17:03:02
VOl-00_01e - Dec 03 2003 17:03:17
dpm_mgr VOl-10_01e - Dec 03 2003 17:03:28 - Eel 3.5 beta-D
SYSERR Sys expander (209): DPM manager died prior to registration (NO such process).
SYSERR sys loader (209): Mark VI Rack record 11762 load failed
expander,(209): DPM manager died prior to
tcoraceinfo
password:
logi n: root
password:
# traceinfo
oct 14 23:59:51 3 00006007 4 clusters allocated at 44818
oct 14 23:59:51 3 0000600a 10 mbufs allocated at 4D500
Oct 14 23:59:51 3 00006007 4 clusters allocated at4DD78
oct 14 23:59:51 3 0000600a 10 mbufs allocated at 4FF80
Oct 14 23:59:53 2 00004854 00000001
oct 14 23:59:53 2 00004854 00000001
Oct 14 23:59:54 3 0000600a 10 mbufs allocated at 50880
oct 14 23:59:54 3 0000600a 10 mbufs allocated at 50EOO
oct 14 23:59:54 3 0000600a 10 mbufs allocated at 51400
Oct 14 23:59:54 3 0000600a 10 mbufs allocated at 51980
oct 14 23:59:55 5 10000001 uc2000/adl_queue
Oct 14 23:59:55 3 0000600a 10 mbufs allocated at 52200
Jul 27 14:52:39 2 0000100c Kick 87 53 2 //l/bin/sh
Jul 27 14:53:09 0 10000001 SYSWARN dpm_mgr: Dual port initialization timeout, check
clock source.
Jul 27 14:53:09 0 10000001 SYSERR Sys
Jul 27 14:53:09 0 10000001 SYSERR sys
failed
Jul 27 14:53:09 0 10000001 SYSERR sys loader (209): Application file load failed
, page 2 '
with error 209
# traceinfo
password:
login: root
password:
# traceinfo
Oct 14 23:54:18 3 00006007 4 clusters allocated at 44818
Oct 14 23:54:18 3 0000600a 10 mbufs allocated at 4D500
Oct 14 23:54:18 3 00006007 4 clusters allocated at 4DF98
Oct 14 23:54:19 3 0000600a 10 mbufs allocated at 50100
Oct 14 23:54:20 2 00004854 00000001
Oct 14 23:54:21 2 00004854 00000001
Oct 14 23:54:21 3 0000600a 10 mbufs allocated at 50980
Oct 14 23:54:21 3 0000600a 10 mbufs allocated at 50FOO
Oct 14 23:54:21 3 0000600a 10 mbufs allocated.at 51480
Oct 14 23:54:21 3 0000600a 10 mbufs allocated at 51A00
Oct 14 23:54:21 3 0000600a 10 mbufs allocated at ·51F80
Oct 14 23:54:21 3 00006007 4 clusters allocated at 52508
Oct 14 23:54:22 5 10000001 uc2000/adl_queue
Oct 14 23:54:27 3 0000600a 10 mbufs allocated at 54AOO
Oct 14 23:54:27 0 10000001 SYSWARN dpm-mgr (-100): SOE queue open failed, error -18.
Oct 14 23:54:27 0 10000001 SYSWARN dpm_mgr (-100): Initial SOE queue open failed,
error -18, continuing any
Oct 14 23:54:27 0 10000001 SYSWARN egd_exp: EGD filter cfig for NetDrV.1 complete
Oct 14 23:54:27 5 10000001 alm_q_srvr
Oct 14 23:54:33 3 0000600a 11 mbufs allocated at 55200
Oct 14 23:54:33 3 0000600a 10 mbufs allocated at 55800
Oct 14 23:54:42 3 0000600a 10 mbufs allocated at 56080
Oct 14 23:54:45 3 0000600a 10 mbufs allocated at 56600
Oct 14 23:54:49 3 0000600a 10 mbufs allocated at 56COO
Oct 14 23:54:50 3 0000600a 10 mbufs allocated at 57180
Oct 14 23:54:50 3 0000600a 10 mbufs allocated at 57700
Oct 14 23:54:51 3 0000600a 10 mbufs allocated at 57c80
Oct 14 23:54:57 0 10000001 SYSWARN dpm_mgr (-100):, send_soe_msg failed, status ~ -20
# proc output to serial port 3f8 at 9600 baud
cd /usr/bin
platform -u &
platform V02_0l-01c - Dec 03 2003 17:03:08
Uc2K-start: Platform Registration After 5 seconds.
en1: fla~s~8863<UP,BROADCAST,NOTRAILERS,RUNNING,SIMPLEX,MULTICAST>
lnet 192.168.101.45 netmask ffffffOO broadcast 192.168.101.255
cd /usr/bin
sys &
*********************************ft************************** ******
MARK VI Runtime Version v05_02_04C
sys_mk6 V05_02_04c - Dec 03 2003 17:04:55
V070100C OCT 2001
Page 3
uci dl e vOLOO_01c - Dec 03 200317: 00: 52
bgnd V06_05_03C - Dec 03 2003 16:59:00
heartbeat v06_04_01C - Dec 03 2003 17:02:32
diag V06_00_05C - Dec 03 2003 16:59:16
logln: sdi v05_02_03C - Dec 03 2003 17:01:48
adl v07_00_10C - Dec 03 2003 17:03:02
diag_alarm vOl-00_01C - Dec 03 2003 17:03:17
dpm-mgr vOl-10_01C - Dec 03 2003 17:03:28 - ECL 3.5 beta-D
SYSERR sys expander (209): DPM manager died prior to registration (NO such process).
SYSERR sys loader (209): Mark VI Rack record 11794 load failed
login:
Using:
HYPER TERMINAL
SETTINGS:
COM1
PORT SETTINS:
9600
8
None
1
Xon/Xoff
Settings
VT100
ASCII Setup:
Cursor - Underline
ucinfo
Bi os versi on
Fl ash versi on
IP name
IP address
IP broadcast
IP netmask
IP router
~N/A
~V070100C OCT 2001
~H1-s
~192.168.101.45
~192.168.101.255
~255.255.255.0
cd /usr/bin
platform -u &
cd /usr/bin
sys &
V070100C OCT 2001
ucidle
bgnd
heartbeat
diag
1Ogl n: sdi
adl
diag_alarm
cd /usr/bin
platform -u &
Page 1
en1:
cd /usr/bi n
sys &
v070100e OCT 2001
ucidle
bgnd
heartbeat
dia9
1Ogl n: sdi
adl
di ag_al arm
tcoraceinfo
password:
logi n: root
password:
# traceinfo
clock source.
failed
, page 2 '
with error 209
# traceinfo
password:
login: root
password:
# traceinfo
cd /usr/bin
platform -u &
cd /usr/bin
sys &
V070100C OCT 2001
Page 3
login:
Hi
Formatting the flash memory using card reader is not allowed at all and you never can use it for the second time. You have to prepare a new flash memory, install it and using serial loader cable change its IP. Cable and serial loader program are required.
Related articles from Control
Engineering magazine- Automation pioneer Nels Tyring dies at 77, coined term: control system integrator
- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Budget-friendly temperature control unit
- Upgrading control for better polymer performance
- Software pinpoints process interactions
- BP selects SIS for UK deployment
- Automation vendors boost biofuels
- Cyber security issues take center stage in 2009
- AIC Series presents new high energy storage chokes
- Decrease arc flash risk with new motor control center option
Subject to its Terms of Use.
