Jump to a Date
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
The reward of a thing well done is to have done it.
-- Emerson
-- Emerson
www.control.com/rss/
We have an MB+ network spread out over several buildings. There are three fiber optic repeaters (MB+ 490NRP25400) in the network. Two of them work fine and one does not. Each has repeater has a small MB+ network connected to it. We had an electrical storm that took out the last repeater on the network and its two associated MB+ nodes. We ordered a new replacement repeater but we can't seem to get the last nodes to communicate with the repeater (remainder of the network) now. We have tried just about everything but still no luck.
Check the fiber optic, it might also be damaged.
You should get the models 2082 from S.I. Tech, Inc. I just replace a couple from another manufacturer and the Sitech ones are working great since 6 months ago. I even also have another big thunderstorm and no problems at all.
Sitech information is:
http://www.sitech-bitdriver.com
As the previous poster said, check out the fibers. Is it possible you have them switched? If you don't have a fiber tester, a crude method is just put a flashlight at one end, look for light at the other.
Roy
Roy
Related articles from Control
Engineering magazine- Ethernet Direct offers industrial IP66 cameras with Power over Ethernet
- Signal conditioners support universal input, feature detachable display
- Motion control: Omron selects EtherCAT as its next motion bus system
- Wireless: Adoption trends in factory automation
- Tutorial: Instrumentation / DCS integration languages, part 2: FDT
- Connectivity: Embedded LAN module with minimum programming
- New 1-1/8 in. M23 connectors provide 19 pins
- Hatching distributed automation architectures
Subject to its Terms of Use.
