- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss/
Roy
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
If you want a mechanical device, any turbine or positive displacement flowmeter will work, or if you can put it in, a variable area meter. But you aren't talking about what you are wanting to put through the flowmeter. If you are putting raw sewage through it, there are NO mechanical designs that will work longer than 10 minutes. If you are putting clean water through, or something with the same viscosity, density and particle sizes, any mechanical meter will work fine. Is there entrained air or gas? Mechanical meters, in fact, all meters, don't like that.
Give us more information, and we can give you better advice.
Walt Boyes
Editor in Chief
Control and Controlglobal.com
www.controlglobal.com
Mailto:wboyes@putman.net
Read my blog SoundOFF!! At www.controlglobal.com/soundoff
In the original post Hydrogen gas 200 cfm @ 2 psi 3" line. Can you get a turbine meter with mechanical readout?
Roy
But I would be inclined to not use a turbine meter for H2 at all.
Walt
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
- Process modeling: Spreadsheets support multiphase flow simulation
