Jump to a Date
Twitter Feed
Thermal Overload
- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
- PC reliability?
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Why pay?
"Plaese porrf raed."
-- Prof. Michael O'Longhlin, S.U.N.Y. Purchase
www.control.com/rss/
Hi
i have a 16 port multidrop gateway (modbus to ethernet) and need to test the system fully.
i am looking for a simulator to connect 16 devices to each port and simulate data. This will be connected to a Prosoft card and Control Logix PLC
Do you have any recommendations ?
Nick
Nick
16 Automation Direct DL05's? Couple PC's with 16 serial ports between them and 16 copies of: <img src = http://www.modsoft.co.uk/images/modslv.gif>
I don't know of any simulator software that will simulate 16 devices.
Even if it did, it would only test the s/w side and not whether the h/w was working completely.
Does the gateway convert from Modbus serial to Modbus embedded in Ethernet or Modbus/TCP?
If Modbus/TCP, can you change the port (other than 502)?
If Modbus/TCP and port is settable, you can use Automated Solutions' Modbus Slave ActiveX Control, which allows for settable port. Each control instance can simulate one Modbus slave device.
http://automatedsolutions.com/products/modbusslave.asp
Not sure exactly what your hardware configuration is, but Cyberlogic has a software bridge product for Modicon networks that may get you where you want to go. It can route messages between any combination of Modbus/Modbus Plus/Ethernet networks and can redirect the messages.
You could set up a single device to provide the data, and use the bridge to re-route all of the messages intended for all of the sixteen devices to that one device, so one will respond as sixteen.
If that sounds like a viable approach, you can contact us at techsupport@cyberlogic.com.
Dan
Dan
Check ControlToolbox Modbus Plant Simulator at http://www.controltoolbox.com/modbus_tcp_plant_simulator
Related articles from Control
Engineering magazine- 60 megawatts of energy produced from landfill gas
- Mipac optimizes plant processes using service platform
- Near infrared analyzer platform helps optimize process
- Alstom launches new Alspa Series 6 control system offering
- Emerson expands capabilities of asset management suite
- GE Fanuc adds new controller to its Proficy family
- Commentary: Wireless for process moves beyond instrumentation
- Wago Topjobs 24 diode, disconnect and LED terminal blocks
- Honeywell to acquire RMG Regel+Messtechnik with its natural gas measurement and control technology
- Motorola wireless mobility: More integration, automation efficiencies, sensors
Subject to its Terms of Use.
advertisements
What end users are looking for. Strengthen vendor programs.
designs and builds smart, lean automation solutions for almost every manufacturing sector. Learn more...
Find the right Modbus device for your project... or list your Modbus device on the largest online Modbus device directory.
