Inverter Siemens Midimaster
shiddiq
Hi all,
I used first PLC S7-300 with Profibus to control the inverter Micromaster. At the time Micromaster had a problem, so we replaced it. We used Midimaster to replace it. We changed the configuration in the PLC, and replaced Micro with Midi. But the Midimaster vector cannot work by PLC, but still works manually. I enabled the Profibus in the inverter in parameter P099. I switched to one if use Profibus, and it is still not working. I didn't change anything in the PLC program.
Please help me, does anyone know what the parameter in the inverter must be entered by me?
Thanks.
