- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
www.control.com/rss/
In process industry a pump running 'dry' is often a big issue (or is it in just my place of work!!). generates a lot of hue and cry. mostly there is a logic that will trip the pump if the tank/sump level goes low. My question is what will really happen if the pump will run dry in case the low level switch doesnt work. To my belief the motor should be 'happy' since there's no load now. but I know I am missing something. request to please explain me why shouldnt the pump-motor be allowed to run dry.
thank you all
Ritika
It is a big deal. Make sure that the check valves in the suction work right.
Walt Boyes
Editor in Chief
Control and Controlglobal.com
www.controlglobal.com
Mailto:wboyes@putman.net
Read my blog SoundOFF!! At www.controlglobal.com/soundoff
normally short periods are ok. but i think im right in saying that the cooling comes form the water being there.
feel free to correct me if this is not your pump type
Roy
Centrifugal pumps or positive displacement pumps (gear type) require flooded suction. During pump rotation part of the energy is converted to heat and is taken away by process fluid. When process fluid is not available, the heat is absorbed by pump internals which are:
1. Dissimilar material and has different temperature coefficient of expansion.
2. Pump internal clearances are very low to achieve high efficiency,
leading to rubbing at high speed and subsequent seizing. This mostly happens with weir ring, which has normally the lowest clearance.
Centrifugal pumps may be designed with high clearances to allow the pump run dry for certain duration but you loose efficiency. Also a less maintained pump over long period develops higher clearances allowing the pump to run dry for a while.
If reliability of level switch is a question, you may replace it with a transmitter or may adopt 2003 voting with level switch, if the pump failure is costly.
Regards.
It's a mechanical issue. Usually sealings are destroyed first by dry run, then water (or any other medium) goes through damaged sealings into the bearings causing their malfunction.
Piotr Kowalski
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Digital manufacturing: Autodesk Inventor shows component interactions
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
