- PC reliability?
- Windows, real time
- PID loops
- PCs vs. PLCs
- Replacing people
- MS 'monopoly'?
- Software quality
- Where do we go from here?
- Why pay?
A person who boasts himself hard to please because nobody tries
to please him.
-- Ambrose Bierce, "The Devil's Dictionary"
www.control.com/rss/
Typically;
'Setup com port parameters
com port settings 19200,N,8,1
'Init
ATE0 <cr>
'Set Text Mode
AT+CMGF=1 <cr>
'Set Number
AT+CMGS="01234567890" <cr>
'Send Message
Message & Chr(26) 'ctrl Z
You should of course check for the correct response after each command i.e. 'OK'. I would connect the modem to a PC first and use something like hyper terminal to test the commands. I assume the PLC com ports can be configured the same way as an SLC where the serial DF1 port can used as plain ASCII port.
Regards Kevin
- ABCs of SBCs: Single board computers for embedded control; Lego learning
- Less, more: NEMA cites less confidence; NAM sees more exports of manufactured goods
- Free webinar on Zigbee for embedded systems
- Better together? Ametek, Dresser-Rand, IntervalZero, Rexroth make acquisitions
- You need 2 monitors: This Website will prove it
- Preview: Mitsubishi iQ controls sequence, motion, process, CNC, robotics; has connectivity
- 30 new Rockwell Automation products integrate hardware, software
- Software certified by AT&T: Runs on PDAs, cellphones, enables mobile applications
- Research: HMI supervisory software use increases with service needs
- Process modeling: Spreadsheets support multiphase flow simulation
