Using 591P to supply power for field coil of sychnorous motor
Chungtq
Dear all,
We want to use DC driver 591P (SSD driver) to supply power for field coil of synchronous motor. We know 591P can use for this application. But we are new in this field. Please let us know what parameters need to set with this application.
Thanks and best regards,
Chungtq
While this is a simple thing to do with this drive, it will take too much to describe it here. In summary you want to go to the Field Control menu and enable Field Control. You will need to setup the Field Current parameter so the drive won't let the field have too much current. There are other field parameters for doing field weakening etc.
For a list and details get their manual and go to the Field Control Section.
or call their tech support:
CHINA
Parker Hannifin Motion & Control
(Shanghai) Co. Ltd.
SSD Drives
Suite B2109 21st Floor,
Hanwei Plaza, 7 Guanghua Road
Chaoyang District, Beijing 100004
Tel: +86 (10)6561 0520/1/2/3/4/5
Fax: +86 (10)6561 1070
