PLC SCADA system
Sam
Hello!
We are buying an application which can design supervised systems. We have a Wago Ethernet TCP/IP controller. Is there an application that can design and obtain digital and analog data from a Wago PLC controller? We need at least to connect PLC digital data to a SCADA like program for monitoring.
Sam
[email protected]
P
Pierre de Bailliencourt
> Is there an application that can design and obtain digital and analog data from a Wago PLC controller? We need at least to connect PLC digital data to a SCADA like program for monitoring. <
Hi!
We designed an importer for WAGO Codesys programs allowing you to select your PLC/codesys variables to import into a PcVue HMI/SCADA Software. If you need more information, you can also contact me at [email protected]
Pierre
