E
I have Siemens S7 PLC that control primary packaging robot and comunicates with secondary one over Ethernet.
I want to use second Ethernet socket and connect PLC to factory data collection system but I plan to connect it using different IP address than the one to communicate with secondary robot.
Is it possible and if yes - how to assign second IP address to the same Siemens S7 PLC (I believe it's called IP aliasing)?
Thanks,
Eric
Thanks,
Eric
