I
Dear All,
I have a situation where i need to control the speed and the stroke of a metering pump using only one Analog output signal. The speed will be calculated automatically by the controller using PID control loop. The setpoint will calculated from the required dosing rate and the process variable will the flow of the pump. The stroke will be a direct setpoint from the operator. My question is how to include the effect of the stroke setpoint in the control loop? i mean what will be the effect of the stroke in the analog output from the controller?
best regards,
Ibrahim
best regards,
Ibrahim
