G
Respected sirs,
In our CPP there are 6 gas turbine generators( frame 9e ).my first question is "what will happen if anybody by mistake switch off mark-6 power supply , when gas turbine generator running normal?"
My second question is if GT is under shutdown with mark-6 supply isolated & if anybody energize any motor feeder in GT MCC , then will it run or not? In some motor feeder drawing starting command contact shown NC contact , while in some no contact used. What is the logic behind using different contacts in different motor feeder?
