from the mechatronics department...
about scada by s7-200
Computers in manufacturing; also hardware discussion. topic
Posted by alaa on 23 February, 2009 - 11:27 am
hello all,
I need an informations help me in my graduate project i have used wincc v6 to connect s7-200 plc to make scada control and monitoring, the question that can i use this program in my project if yes could you tell me how to connect the plc to the wincc. if not i hope you to suggest another program to use.
note, I have no more 3 months.
Posted by NT on 23 February, 2009 - 5:56 pm
Yes, you can use the MPI connection in WinCC to talk to the S7-200.
Posted by Saad on 25 February, 2009 - 4:17 am
Dear Friend,
You cannot communicate from S7-200 to WinCC using MPI. This can only be done via OPC. This is a little tricky.
If you want to keep things simple go for WinCC Flexible. As S7-200 works on PPI interface instead of the MPI iterface and WinCC doesnot understand PPI. But WinCC Flexible does.
Saad
Posted by Mark on 25 February, 2009 - 5:51 pm
PeakHMI can communicate with an S7-200 using PPI.
http://www.hmisys.com
Hope this helps,
Mark
Posted by alaa on 27 February, 2009 - 5:40 am
thank you i will try this software
Posted by Dilip on 27 February, 2009 - 12:54 pm
its true you will not be able to use WinCC v 6.0 with S7-200 use WinCC flexible instead.
Nature is by and large to be found out of doors, a location where, it
cannot be argued, there are never enough comfortable chairs.
-- Fran Leibowitz
Advertise here
advertisements
Learn from those who do, and become the expert today. Training Levels 1, 2, and 3 are available. Register Now!
our advertisers
