R
Hello all,
We are planning to pick our next development project. The idea is to come up with a plug and play component written under .Net Framework/Compact .Net Framework, similar to NetPro Modbus Master [see www.controltoolbox.com].
We like to share some ideas with you guys and get your feedback. If you may, please try to include the following points in your feedback:
* Existing competition if any
* Industry and the applications it can be used
* Country and the industry you are working in
* How you like to see the licensing for each particular case (for example per RTU, per point, per number of communication bytes etc)
* Any feature you like to see with the solution
* How much would you think the solution worths to you.
Now here are the ideas:
[1] Data communication protocol module: Examples: Modbus client, OPC server/client, DNP3 master/slave, etc. The module can be accessed via network APIs [including a wide area network and M2M] to read/write and receive events.
[2] Independent Alarm Module: Be able to define an alarm module independent of SCADA, as an OPC client and be able to communicate via network APIs such as Remoting, Web Services or other WCF [Windows Communication Framework] mechanisms. Be able to define object hierarchy, different alarm zones and classes and script the alarm conditions rather just H, HH, L and LL conditions. Be able to delete, add, inhibit and un-inhibit online. Be able to acknowledge an entire parent area. Be able to view reports and alarm history based on filters such as zone, class, area, time etc.
[3] Independent Historian Module: Be able to define a historian module independent of SCADA, as an OPC client and be able to communicate via network APIs such as Remoting, Web Services or other WCF mechanisms. Be able to view reports in online and batch mode based on filters such as zone, class, area, time etc.
Please let us know if there is any other solution that you wish somebody develop it for you.
Thanks in advance for sharing your ideas.
If you like, please email us directly at [email protected]
