from the Hope department...
Comunication Problems on Profibus Yokogawa and Siemens
Application Questions and Problems topic
Posted by Jesus Carrero Blanco on 20 March, 2009 - 8:02 am
Hello I try to put a normal profibus-DP network between Yokogawa ALP111(as a master) and a Siemens ET200M IM153-1(SLAVE) with a 32xDI module attached(6ES7-321-1BL00-0AA0).
We already use the SyCon obtained from Yokogawa(SyCon-PM/YOKO or SyCon-DNYOKO), and we have the License or Keycode LFS2542 for Profibus Comm. on Yokogawa CS3000 R3.08. Also we import to SyCon the ".GSD" file for "ET200M IM153-1" from Siemens.
We configure the SyCon and generate the ".dbm" file and imported to the module ALP111 properties on System View.
We fill the %%WWxxxx table on System View for the module. We download and undpate the controller, and we get a Comm. failure "CA91" on the CS3000 and a flashing BF red led on the ET200M.
We check almost everything with out results.
What do you suggest to check?
Thanks.
Posted by Steinhoff on 20 March, 2009 - 1:24 pm
There is a bus fault. Is bus segment correct terminated?
Best Regards
Armin Steinhoff
Posted by Jesus Carrero Blanco on 24 March, 2009 - 3:44 am
Hello again.
We already find the problem in the configuration on the Master ALP111 in SyCon.
We deactivate the DPV1 setting on the Master, and we get comunication.
That means that the ALP111 is only profibus DP and not DPV1, instead that the ET200M support the last one.
The rest was easy cake.
Thanks.
Posted by m on 10 April, 2009 - 9:18 am
Hello
How can I find the following GSD file?
>Hello I try to put a normal profibus-DP network between Yokogawa ALP111 (as a master) and a Siemens ET200M IM153-1(SLAVE) with a 32xDI module attached(6ES7-321-1BL00-0AA0).
Thank you
Regards.
Mohammad.
Posted by dchartier on 10 April, 2009 - 11:07 am
Hello Mohammad;
Try Siemens' support website: http://support.automation.siemens.com/WW/view/en/113498.
Save the link, it is the best location for manuals, downloads and sample programs for Siemens automation and drives product. Learn to use the Search feature (try the "New search" link on the left) to find information on the site.
Hope this helps,
Daniel Chartier
Posted by Moazzam on 11 May, 2009 - 1:40 am
Where can I find ALP111 GSD file.
Posted by Jesus Carrero Blanco on 8 June, 2009 - 4:10 am
Hello Mr.
I find this recently, please check if this is usefull for your aplication.
Thanks.
Create a GSD file with this:
------------Don't put this line start in the following line ------------------
;* GSD-file for ACP71 (CENTUM CS PROFIBUS-DP communication module) *
;* Yokogawa Electric Corporation *
;* PROFIBUS DP - Developement *
;* Filename: YEC_0838.GSD (c) 2003 *
;* GSD file version 2 from 07.05.2003 *
; ATTENTION:
; Changes in this file can cause configuration or communicationproblems.
; This file is compatible to the firmware of the device.
; Changes
; 07.05.2003 F. Mizushima
; - Customize from COM-C-DPM (by Hilscher GmbH)
; - created
#Profibus_DP
GSD_Revision = 1
Vendor_Name = "Yokogawa Electric Corporation"
Model_Name = "ALP111"
Revision = "R1.01.01"
Ident_Number = 0x0838
Protocol_Ident = 0
Station_Type = 1
Hardware_Release = "Version 1.000"
Software_Release = "Version 1.000"
9.6_supp = 1
19.2_supp = 1
93.75_supp = 1
187.5_supp = 1
500_supp = 1
1.5M_supp = 1
3M_supp = 1
6M_supp = 1
12M_supp = 1
MaxTsdr_9.6 = 60
MaxTsdr_19.2 = 60
MaxTsdr_93.75 = 60
MaxTsdr_187.5 = 60
MaxTsdr_500 = 100
MaxTsdr_1.5M = 150
MaxTsdr_3M = 250
MaxTsdr_6M = 450
MaxTsdr_12M = 800
Trdy_9.6 = 11
Trdy_19.2 = 11
Trdy_93.75 = 11
Trdy_187.5 = 11
Trdy_500 = 11
Trdy_1.5M = 11
Trdy_3M = 11
Trdy_6M = 11
Trdy_12M = 11
Tsdi_9.6 = 70
Tsdi_19.2 = 70
Tsdi_93.75 = 70
Tsdi_187.5 = 70
Tsdi_500 = 150
Tsdi_1.5M = 200
Tsdi_3M = 250
Tsdi_6M = 450
Tsdi_12M = 800
Tset_9.6 = 1
Tset_19.2 = 1
Tset_93.75 = 1
Tset_187.5 = 1
Tset_500 = 1
Tset_1.5M = 1
Tset_3M = 4
Tset_6M = 8
Tset_12M = 16
Tqui_9.6 = 0
Tqui_19.2 = 0
Tqui_93.75 = 0
Tqui_187.5 = 0
Tqui_500 = 0
Tqui_1.5M = 0
Tqui_3M = 3
Tqui_6M = 6
Tqui_12M = 9
Redundancy = 0
Repeater_Ctrl_Sig = 0
24V_Pins = 0
Max_MPS_Length = 100
Max_Lsdu_MS = 32
Max_Lsdu_MM = 32
Min_Poll_Timeout = 1
Las_Len = 125
Max_Slaves_supp = 125
Bitmap_Device = "ALP111_R"
Bitmap_Diag = "ALP111_D"
Bitmap_SF = "ALP111_S"
------------Don't put this line ------------------
Thanks.
Posted by Sheeda Teli on 15 June, 2009 - 1:22 am
Hello Mr.Carrero Blanco,
I really impressed that what modification u done in your offered GSD file for ALP111. Lolz but great because it realy helps people.
Sheeda Teli
The meek shall inherit the earth -- they are too weak to refuse.
Advertise here
Advertisement
our advertisers
