P
dear sir,
We have 2 ge 7ea machines. both are completed hgpi but for one unit the MW output is lesser than the other unit. the diff is 4 MW normally 75 mw but now 74 mw.
so it was happend after hgpi we verified with ge observed cpd is less 0.4 than the actual value. and also verified pasiing of ibh and bleed valve and all other sources but everything found ok. igv showing 84 deg baseload so ge taken shutdown repalced lvdt and calibrated started back the unit but still at base load output is less and cpd also less value. so please give me the suggestions to rectify the problem
