W
I need to control solenoid valves in an irrigation system over an existing two wire network. There is an existing irrigation control that does this now, but is very limited when it comes to any sort of complicated control functions, like moisture inputs, etc. The client wants to replace all of it with a new system that will tie into an existing iFix HMI.
What protocols or options are there for doing this? There are some runs that have up to 90 valves daisy chained together...almost 800 valves split up over several networks (13 I think?). From what I can gather, the existing controller sends out a "pulse" to both tell the correct valve to open, plus actually swap the valve state.
Thanks for any help or insight.
