Hi everybody
I am making a java tcp slave where i have two memory maps that are gone to be readed/written by other device:
Map1: from 40001 to 40003
Map2: from 45001 to 45100
The problem here is thar I don't know how to make this because my first idea whas making this way:
public ModbusSlave (int port) {
//Next we add the instances and variables the application will need, acquiring the value of the port number from the first commandline parameter if given:
/* The important instances and variables */
ModbusTCPListener listener = null;
SimpleProcessImage spi = null;
//Next we will construct the process image and setup the coupler to hold the reference:
//2. Prepare a process image from 40001 to 40003
spi = new SimpleProcessImage();
spi.addRegister(new SimpleRegister(0));
//2b. Prepare a process image from 45001 to 45100
spi.setRegister(45001, new SimpleRegister(0));
//3. Set the image on the coupler
ModbusCoupler.getReference().setProcessImage(spi);
ModbusCoupler.getReference().setMaster(false);
//4. Create a listener with 3 threads in pool
listener = new ModbusTCPListener(3);
listener.setPort(port);
listener.start();
And Instruction 2b makes me an error (logically) , because this memory direction has not been added to the SimpleProcessImage (is a vector and instruction crashes).
How can i solve the problem? ¿Do i have to add registers from 40003 to 45000?
Tx in advance
listener.start();
Tx in advance
