My problem is that I'm trying to communicate with different processors through a network. I can see these different processors in linx as a unrecognized device. I have tryed to change the TCP/IP of the laptop to match the address of the network that I'm try to use. This is not working. I have seen other people log into this network useing the same connection. I believe that the problem is in the laptop and that there is something wrong with it's settings. Has any see this before and can you help!
